dakotafear3088
- 0
- 6
- Danville pa
i need to add a gauge to see what the garage did to my truck, and I got 2 different answers of what gauge I NEED ! I bought the Boost gauge as I was told that would be far better and more accurate than the pyro for how much the engine is doing since it was "played with" Basicly it seems that if you keep your boost below 15 then the EGT should be at a safe level. yes no? I cant afford both now, but I dont want to take chances on ruining the engine. it has a front headgasket leak but still holds its own and isnt loosing compression. so I want to re-tourque it forst and then if need be replace the gasket. ( was sold the 2 piece unit) is this ok? anyway any help would be greatful
Thank you
Thank you
