Which hole?
FMJ
37
Las Cruces, NM
Do I use when towing a Deuce, with a Deuce/109A3? I believe it was stated to keep the bar as short as possible, so with a medium towbar what hole do you use/recommend? :wink:
My bar came without pins, so I bought grade 8 bolts to replace them and would like to set the length before I go to get my trucks.
gimpyrobb
dumpsterlandingfromorbit!
27,786
755
Cincy Ohio
It doesn't really matter. A little longer will help with leverage. Make sure the front tires are FULL of air, it will follow better.
1,131
Do NOT use Grade 8 bolts. I have read in multiple places that bolts will damage the towbar and that you should use pins, available from your local Tractor Supply Company.
M1075
Oklahoma City
You got the right holes, but I would also suggest the 3/4" pins. BTW, I ordered 5 large boxes of tools & stuff from Tractor Supply over the internet, and I got it UPS in 2 days!
FMJ
37
Las Cruces, NM
Re: RE: Which hole?
? How ?, as long as the shoulder of the bolt goes all the way through the bar, how will it damage the bar? The only pins I could find in town were grade 5, and stamped "made in India"......
chevycrew
Woods Cross, Utah
RE: Re: RE: Which hole?
If the bolt is harder makeup than the bar, it will cause the wear to the bar and not to the bolt/pin. I really dont like using grade 8 bolts when it is encountering a side load. When a grade 5 bolt may bend, a grade 8 bolt will snap.
I would have no problem using the grade 5 pins.
There is not really any charts to show the actual shear strength of bolts, most just show tensile strength. But either a grade 5 or grade 8 will be overkill in this application.
emr
25
landing , new jersey
the bolts are fine, ive got alot of miles on one of my bars with bolts, its all in the shoulder like U say, obviuos.. its a pin with thread on the end, It states the use fine, short as possible, for strength, BUT as long as U wont pinch the bar, turning, Ive found one or 2 holes in mosttimes, i have never had em all they way in unless towing the M38, the deuce and 5 tonners need some swing room, U can ruin any of them weather in or out if U dont be carful... Randy
emr
25
the grade 8 bolts are way better then the 5 pins from the old ship grave yard steel from india, and like U said shoulder is the key, but be realistic, U will never use it enough to wear the bolts or pins out, the bolts keep it tighter so less slop butthere is so little anyway its not worth worring about, Randy
FMJ
37
Las Cruces, NM
Thanks Randy, the 3/4 in ones in the legs have nylok nuts so they wont need to be real tight, no threads in the holes either....
