Which Relay??
southdave
ripley, oh/TDY Lordstown,Oh
I am kind of stumped.. I start the truck, generator ga. is on the yellow/ green line. Goose the eng. to get rev up gen light climbs a bit. 3.5 min I hear click and the gen. ga jump to green/red ??? I am making 29.5 volts at the rear bus
front battery and alt are reading allittle high the others are good??? The clicking noise changes my Idle too..
gvaneck
lansing il
Sounds like your glow plug relay is staying on too long possibly? Could that be it, check voltage at the bottom lug of glow plug relay when it does this
Wolf.Dose
9
Boehl-Iggelheim, Germany
If it should be your glow plug relay, replace it or your glow plugs sooner or later will be shot. Replacement might become a nightmare. The computer card of the glow plug controll is NOT made for longer actuation and will give up its limited live soon.
Wolf
southdave
Yeah, wolf I am trying to head that off, I think I have smoked them already (glow plugs).... I did swap relays for the ST 85 one thats when my problem began. I have been more concern with my alt over charging I have some wierd reading with the volt meter ect.. 13.9 on my front battery and 15.65 on my rear. Note I moved my Batteries to the inside rear of the the 1009 to accomodate a turbo and fuel filter rack ect.. I think I just have batts. that need to equalize??
Barrman
1,767
Giddings, Texas
I agree it is a load somewhere on the system. However, it could very possibly be a bad voltage regulator as well on one of the alternators. I think it is glow plug related, but just wanted to mention what to check next if you find everything ok.
Warthog
232
OKC, OK
Since you moved the batteries to the rear, how did you wire them up? Is each battery wired to its own alternator like the stock setup?
southdave
Maybe thats it.. I just hook the bat. leads to the rear bus bar in the 1009 similar to the front . I left the wires from the alt where they where. the neg from 12v side of bat. set was ground to the old radio bracket mount @ the floor. the pos. side of the battery set, ( I got billy with it) I used 6 ga wire from a set of jumper cables, It cheaper to buy then 16 ft of 6ga, wire, to the 12v thingy on the fire wall. yeah I splice in the fuse..
I just figured I was just making a set battery cables, was wrong in this thought? Maybe I need to mactch the lugs from fron to back? figured it all dumping in so it didn't matter?
