- 1,813
- 1,513
- 113
- Orlando, FL
By "toward the wheel face", am I understanding correctly that the long nose would face inward toward the axle?Mine are even spaced on both sides. More than likely they were for the aluminum RG31 wheels. I believe the lip went towards the wheel face on the caiman aluminum wheels
Thanks. How do I tell the wheels apart?No. The wheel face for your outer part of the wheel you remove to remove the tire. The nose will face away from the truck on a LMTV wheel
Do you have the older LMTV wheel or the accuride wheels?
395s and 1600s use the same composite runflats. Yes it has its own beadlock functionis their a run flat for the 14 R20's? or would it be same runflat?
does the runflat "replace" the inside beadlock ring?
same for rubber run flats too?395s and 1600s use the same composite runflats. Yes it has its own beadlock function
Yessame for rubber run flats too?
Back when I got mine off eBay, they could barely give them away. I think I paid like $40/ea, and shipping was free or cheap. I haven't seen them in a while, though.Anyone know of a good source for these?
You can ask Dustin at feltz if you can get em shipped from Texarkana. They break down all tires and wheels that leave from RRAD. the inserts just don't get shipped to Wisconsin with the tires/wheelsAnyone know of a good source for these?
