White deisel M35a2-
Haveittoplease
Wyoming, Mich.
I'm a Newbie so I'll be short. I have all the stats on fluid capacities for an m109a2 and its White D-turbo. Can some one give me what type of fluids
1. crank-case oil to use
2. what type of coolant to use
3. grease nipple size ,I know it can't be the size of civilian cars 1/8 inch, 1/4 inch, 30mm? what type of grease-name, viscocity?
4. fuel filters are they the 30 micron?
5. Type,name of a good differential fluid?
1,158
Ok, I am going to lock this thread after I post this, as this stuff has been covered so exhaustively there is just no point in doing it again.
haveittoplease, welcome to the site. We're glad to have you!
We've been collecting information about these trucks for the better part of a decade and as you can imagine, these topics have been covered in great detail.
You need to make sure you've read your Tech manuals (including the Lube order, which would answer several of your questions) and you need to make sure before posting, you've searched the site to find what you're looking for, as pretty much any deuce related question has been answered already.
Search takes a while to master so we suggest reading older threads as a way of acclimating yourself to the site, our culture and the information.
EDIT: I also moved the thread from the "website help" forum to the Deuce forum. The website help forum is for assistance with issues relating to the website, like not being able to post in the classifieds, etc.
Since you're new, I'll help you out:
1.
http://www.steelsoldiers.com/deuce/83387-swede-need-engine-oil-advice.html
2.
http://www.steelsoldiers.com/deuce/84594-antifreeze-deuce.html
http://www.steelsoldiers.com/deuce/64418-deuce-cooling-system-clean-out.html
http://www.steelsoldiers.com/deuce/9128-cooling-system-maintenence.html
http://www.steelsoldiers.com/deuce/...reeze-coolant-important-antifreeze-facts.html
3. I don't know the size but my standard grease guns fits all the zerks on the truck. They're SAE but I don't know what size.
4.
http://www.steelsoldiers.com/deuce/76477-pics-filters-gaskets-help.html
http://www.steelsoldiers.com/deuce/88550-installing-new-primary-filter.html
http://www.steelsoldiers.com/deuce/69854-deuce-filter-micron-size.html
http://www.steelsoldiers.com/deuce/51936-fuel-filter-question.html
5.
http://www.steelsoldiers.com/deuce/76932-lube-order-versus-what-i-am-told.html
