Why does the front axel have a thing on top of it?
shadow
Cedar Rapids, Iowa
I had to move my tractor yesterday and a buddy of mine noticed the front axle has a thing on top that looks like it would be used to connect it to another axle. I have no idea what it is. I found a pic online of one that looks like mine. What is that thing for?? It has a square flange with 4 holes in it just above the center section.
1,178
It is on all the axles! All 3 of your axles use interchangeable parts. It (drive flange) is just not used on the front of the front axle. Look under the rear of your truck and you should see one there too!
Jones
Sacramento, California
So you can use the differential center section (third member) in any axle location. The same assy will fit and work in all axles so you don't have to have a special one for each axle position. The four bolt flange is what the drive shaft bolts to.
M1075
Oklahoma City
Key word is parts interchange. Especially if you want to convert to 8x8! Or, you can build a "big dumb trailer" and power it like our man Spicergear. You can also use these to add pinion brakes (I have them on my jeep).
OPCOM
27
Dallas, Texas
it's for the baby HEMTT.. I have thought about the possibility of mounting an air conditioner compressor via pulley to that thing. A torque bar mount from a rear axle could be the basis for a mount. Not sure if the drive flange would take a side load. Other uses: spare alternator drive, and of course the hypnotic pinwheel.
