Why is the wheelbase on the driver's side om my 1009 an inch longer than the pass..?
soulbrojosh
albion, mi
I have been having some rubbing issues with the front, passenger side tire on my 1009. I currently have 33x12.5x15lt on all 4 corners. the tire only rubs when the suspension is engaged on a right turn. I spoke with a Tuffy mechanic who told me that i should measure the distance between the front and rear hubs, on both sides. The drivers side is an inch longer. My question is what would cause this? Bad spring bushings, has the axle shifted, a loose u-bolt on the pass springs? Is it something that i can fix; short of cutting my fenders.
I have tried searching the forums, and haven't had much luck. I see that a lot of members have no problems with 33's but it looks like a lot of the 33's are 10.5 not 12.5.
cpf240
Free in Northern Idaho
I would guess that something has shifted, as you already mentioned. Having a frame shop look at it wouldn't hurt either.
Having said that, the size tires you have on there are, in general, a hit or miss thing as to whether they will rub or not. It seems to vary from truck to truck, and tire make/model, etc.
Skinny
488
Portsmouth, NH
A very flat surface (preferably concrete), a plumb bob, chalk, and a tape measure will answer your questions. Take a few points on each side then compare. You may also be able to dig up some service measurements if you know someone who works at a collision center.
1,178
Your tires are too big.
swiss
841
Oakwood, Ga
BFG 33x12.5 will not rub if your front end springs are good and no GL forklifts into the fenders:) They look good also
soulbrojosh
albion, mi
Thanks, Doghead! But i like them, and they will stay unless it is cheaper to buy 4 smaller tires instead of buying new front leafs...or whatever else the prob may be.
soulbrojosh
albion, mi
thanks Recovry4x4... i will have to wait until it stops raining before i can get underneath it and check...but since i started this thread, i have had some starter issues and am in the process of trolling the threads to find some answers (riding on the shoulders of giants!!)
11Echo
92
CT W. R.
I've run BFG 33/12.50-15's on half ton GM Pickup, Blazer, and Suburbans for 40 years without lift or problems. That is with GM 8" wide wheels.
soulbrojosh
albion, mi
While i was wiring in my push button GP, i was waiting for my drill battery to charge. I decided to check out the underside of the front end and noticed that the pass side sway bar front frame mount bushing was torn up.
Would this cause my front axle to head rearwards? Because all of the other parts looked solid.
Drock
12
Eatonton GA
The sway bar serves no structural purpose so no. However it could be ah good indicator as to your problem. As Recovery said about the leaf spring center pin. Or someone could have hit ah tree stump or curb really good and simply bent something like the leaf spring itself. I would take some careful cross measurements of the frame and engine bay to determine if the truck body & frame are straight. If so then you'll know your problems in the suspension.
Drock
12
Eatonton GA
If there's frame damage or bent suspension components, at best an alignment would only mask the problem. Assuming they could even get it TO align. The truck would run down the road like ah crab and do some weird things when you changed lanes, AND still wear out the tires. It should only take ah creeper, ah friend to hold the tape, and half ah beer to do ah couple "X" or cross measurements using bolts or bolt holes in the frame that are the same on both sides. Then you'll know what your dealing with and can make an informed decision.
soulbrojosh
albion, mi
That sounds easy enough...I work next to a Tuffy and one of the alignment techs mentioned something about these trucks being off center on purpose, something about a shorter turning radius to one side. Any truth to that. I am still gonna be on the creeper taking some measurements, but just curious?
Drock
12
Eatonton GA
I think what he is referring to is what's called the (Ackerman angle). And yes, solid axle trucks would have strange turning issues where one tire (Usually the inside tire) turns more then the other due to the tie rod design. However your extreme caster/camber issue suggests something's way out of whack. Such as bent frame, or bent or worn suspension parts. Taking your cross measurements is FAST and FREE! and could save you ah lot of time and $$$$$ of replacing ah bunch of parts that didn't need to be replaced if the frame is bent.
soulbrojosh
albion, mi
Got ya. Is that turning issue because of that really long bar that sits in front of the steering stabilizer? What is that called, not a draglink, i'm guessing? I get the feeling that this beast hasn't had any front end parts replaced, ever. To be honest, i am a tad bit intimidated by the size of the components, am used to smaller vehicles. But i am up to the challenge.
Drock
12
Eatonton GA
Without getting overly technical, (Ackerman angle) has to do with the angle (for & aft) of the top of the spindle +steering arm length vs tie rod + suspension travel. So basically as you turn your wheels ,and the suspension travels up and down the geometry of your steering changes. Thus making your wheels toe in or out. I'm sure someone much smarter then me could explain it better, Mama June perhaps:grd:
Triple C
NAPOLEON MO
I was in a wreck with a 4x4 pickup that had the frame bent. When it came back from the shop the driver side (the side it was hit on) was an inch shorter hub to hub than the passenger side. The shop told me it was a bent axle housing (not sure why they didn't find it when they fixed the truck!) As mentioned, the springs/bracket are a good bet but I would check the frame for existing or repaired damage. Good luck.
soulbrojosh
albion, mi
Drock, I wikipedia'd the Ackerman angle and it gave a pretty good descripition of what it was (for once). I am definitely gonna be on my back under this truck this weekend. Thanks for all of the tips!!
