Why pre checks can save your life.
mahdey
Ft. Knox KY
So my M35A2 has been parked since August. I decided, i should drive this thing today and let the fluids circulate some. I check tire pressures, ~42-45 psi, ok, I can let that go. Raise the hood, check coolant, oil, make sure no critters made a nest out of the air filter and all was good. Checked my lights, all operable. So I start her up. Not even a rev. of the starter and it fires right up. Not bad being it's been parked since august and it was 20 degrees out. I let it high idle and once it warmed up. I turned the heater on, slapped in some ear plugs and went to take off. I get down the driveway and press the brake pedal. Straight to the floor. Grab the PARK brake and hop to a stop. Thank God this was in my driveway doing 10mph and not on a street. Usually I don't need to even touch the brakes until I am on the main road, but I realized as I was starting down the drive I forgot to press the brake pedal to make sure it had resistance.
Lesson learned, pre checks can save your life...or a sheet ton of $$ in property damage.
1,807
Good advice. Especially important in a deuce. Many suffer from the dissapearing BFS syndrome.
Dipstick
1,267
Effort PA
I've experienced disappearing brake fluid syndrome myself. In my case it was caused by two leaking rear brake cylinders. I always check brakes before I hit the road.
welldigger
15
Benton LA
I mounted mine on the firewall just so I wouldn't have to mess with that stupid trap door. I can even pressure bleed my brakes from the side panel. That valve in the picture is above a tee that I can hook my pressure bleeder to. I don't have to get under the truck except to bleed the air pack.
Regardless of where you mount it, a remote reservoir is an excellent idea on single circuit brakes. Mostly so the fluid level is easy to check. That way you will actually remember to check it.
Corvette1974
Upper Black Eddy, PA
I had a similar disappearing BFS happen to me in a '47 Dodge 1.5 ton. Backed out of the barn, no brakes. I grabbed the parking brake and luckily it works really well. Drove right into the shop and filled MC. Never happened since, still check the MC every time now!
Will
