Why won’t my doghouse clip closed
thoner7
161
NE TN
My top right doghouse clip doesn’t work and never has. I’ve fixed it and jimmy’d it and replaced the spring clip think but it just doesn’t work. It’s like it’s a half inch short or something?
What gives?
Is there some super secret secret to getting it to work? Any suggestions other than the obvious ones?
mccullek
287
Oxford MS
The metal hooks that the clip grabs bend easily. I had a hard time gettining mine to close until I realized the hooks were bent.
Look at your hooks to be sure one or both are not bent out of place or the shape of them is not correct. They bend easily with a pair of pliers. I found a set of electricians flat nosed pliars work best if you have a pair.
Mogman
8,903
Papalote, TX
Google DZUS and see how they are installed and adjusted, to do it correctly you need some special tools, I have one vehicle with DZUS fittings all over it so the tools are worth while to me.
thoner7
161
NE TN
I broke the one spring trying to clip it in. So I replaced it. But it still doesn’t work.
Mogman
8,903
Papalote, TX
Again they have to be installed and ADJUSTED correctly OR the cover is not correctly fitted,, if it takes allot of force to twist it in place it is not adjusted correctly, DZUS fasteners are rather fragile but there are places they work better than anything else.
I have all these tools and it make fabrication real easy, the "fitting/adjustment" starts at about 5 min. in.
https://www.bing.com/videos/search?q=DZUS+fastener+adjusting&&view=detail&mid=EA91CA879A6224D63047EA91CA879A6224D63047&&FORM=VRDGAR&ru=/videos/search?q=DZUS+fastener+adjusting&qs=n&form=QBVR&sp=-1&lq=0&pq=dzus+fasteneradjusting&sc=1-22&sk=&cvid=8DB875DF8E1B47329121A2F766FA4D80&ghsh=0&ghacc=0&ghpl=
Mainsail
1,539
Puget Sound, WA
My left one had a broken spring when I got the truck. I replaced the spring and now it's very loose, so it really isn't holding that side of the doghouse. The bottom snap-clip seems to be enough but I would still want to get the DZUS adjusted correctly.
