Why you need to have a 3inch axle nut socket in the cab
cattlerepairman
3,201
NORTH (Canada)
...because an XL coffee fits into it perfectly, the nut is heavy enough to sit on the flat middle tunnel beside the gearshift and will not budge, even on a rough country highway. :))
RANDYDIRT
Furlow Ar.
If you open the windshield about 4 inches, you can set your beer on the cowling. Just make sure you have a tittie on it or it will get hot real fast.
Dirt
Heavysteven
10
Hickory Flat Ga
So I am the only one carrying a 3" socket just incase I need to pull a hub. Thought you were going to say you had a hot hub and fixed it in the field.
Good idea but I would have to clean the grease off mine first.
Rifle mount acting as a cup holder is an excellent idea. I need one of those kits.
