Will a box, fit a dual axle trailer and can the LMTV tow it properly?
coachgeo
3,551
North of Cincy OH
What is a "box"? sure your hopeful wife's engagement ring box will fit..... but she will probably say "no" if you put it there.
That trailer is known to be a HUGE HUGE drag. Enough folk have said its hard to even pull it up hills at normal highway speeds for an LMTV...... (which is slow already). The thing is massively heavy. Found one for myself (minus bed) at a good price and will butcher it just to cut the weight way down..... Might not work still.... big gamble.
BKubu
1,256
Gaithersburg, MD
By "box," do you mean an S280 shelter?
Regarding your question about moving heavy military hardware, these trucks were designed to be run in convoys at low speeds on highways or off-road at even lower speeds. Neither of these require the ability to pull hills and maintain top speed. If you want more power, find yourself an A1 with either the 3126 or C7 engine. I prefer the latter, but there are guys who prefer the former due to its simplicity. Even with these engines, though, military trucks, generally, are underpowered (with some exceptions). Good luck!
simp5782
Feo, Fuerte y Formal
9,509
Mason, TN
Would be easier and lighter to mount a S280 on a M796 Bolster trailer. They are much lighter. and would ride pretty level. or a 1061 trailer. the M1082s are a little heavy and frankly just tall.
You can also look for an LMT shelter trailer. It is basically an overgrown 1061.
Awesomeness
1,522
Orlando, FL
I have a M1082 trailer that I tow behind my M1078, and my truck does not even notice it's there. It does not slow me down at all, even on hills (anymore than the 5MPH the truck slows down anyway), and I still cruise along at 58 MPH maxed out. It's pretty much like driving without it when it's empty.
coachgeo
3,551
North of Cincy OH
Good to hear that..... have heard the opposite several times. Which axles ratio are you running... the upgraded or standard?
