Will a humvee key switch work in a M-series truck?
US6x4
2,188
Wenatchee, WA
I have an M813 and I came across this key switch conversion and I was wondering if it would work on my truck. I think the 809s come with a 3 plug switch...
US6x4
2,188
Wenatchee, WA
Ok. Good to know. It's advertised as a humvee application. They probably use that to crank up the price...
Ajax MD
1,414
Mayo, MD
Please let us know if you move forward with this project, and if it works out. I like how the key is disguised as a switch handle.
I'm of mixed feelings regarding installing a key switch- On one hand, it certainly adds a little security. On the other hand, I consider the lack of security features part of the truck's charm.
There's no security but the pattern of switches and order of operation are their own security that sometimes deters casual thieves and joy-riders.
US6x4
2,188
Wenatchee, WA
With key disguised it would be easier to maintain the charm you talk about and still be able to add some protection. I might pull the trigger on this in the spring - we'll see. I go back and forth and maybe a hidden ignition interrupt key behind the dash is better. Here's where I found it and they have more photos.
US6x4
2,188
Wenatchee, WA
Yes, $89 and that disguised key goes one step beyond the other key switches I've seen from others like T.M.G.
I think their listing name is federal-military-parts
Item# 152934722002
US6x4
2,188
Wenatchee, WA
The install in the picture in my first post seems incorrect. Shouldn't there be 1 jam nut behind the dash and 1 jam nut on the outside? They have 2 jam nuts stacked up and it would look stock if they only had an internal tooth lock washer and a single jam nut on the outside painted green
