Thanks for the observation, I don't have the truck here...will get it tomorrow, batteries are probably very dead.jwaller said:you will be lucky to get it going if the batts in the 5ton are totally dead. you might have to let it charge for about 30 min. esp if the 5 ton doesnt bust right off. also you should open the bypass screw on the IP of the 5 ton bc if you dont continue to have; power the solinoid will close off when you pull the slave cable and shut you down. it would be better to find 2 junk batts with a good charge to throw into it to get you going even if you have to boost it with the M35.
