Will a S-788 shelter fit a M1101 /2 trailer?
tobyS
832
IN
It will fit, I have an S-788.
Here is what I'm doing to make the S-788 to fit an 1101. Note the trailer has about 4" of sides above the floor. That's the wheel well depth on the S-788, which I think is about the same on the S-250. In the case of the S-788, it's also longer, so mine will have a slight overhang on the front and rear.
I'm in a bind paying for my daughters wedding so if you may be interested in a trade, I'm selling my project.
Dwnorton1
23
Healdton Oklahoma/ SOOK
I recently bought a 1997 Raytheon Generator Trailer, which is based on 1101, for this this very purpose.
I hope my 788 fits it, but if not I'll just stick my 803 on it.
tobyS
832
IN
It probably will fit but it depends on the center between the wheel wells. Or you could remove those wheel wells and use the opening on the 788. I do think gen trailers are usually narrower but you may have enough room. A lot of the later stuff is at HMMWV width however. Let us know.
tobyS
832
IN
No I haven't. Too many other projects moved it down the list. I have a problem with the back jacks. They will interfere with the shelter, so when I do set it on, a new jack system should be ready to go.
Most of my efforts right now are on making my M35A3 into a 4x4 and making a trailer from the bed. Here is a photo of the deuce bed trailer.
