Glider
- 227
- 43
- South Pittsburg, TN
Have a complete TPI engine local to me available. Will the intake fit without cutting under windshield?
The air filter does not sit on the HMMWV intake manifold, there would be no room for it.Those TPI engines fit just fine in Chevy trucks that the 6.2 with a filter fit in. I actually seem to remember thinking the TPI intake looked short and small under the hood of a squarebody. I think it will fit.
The best way to KNOW is to measure from the crank shaft to the top of the intake. Then ask someone with a HMMWV intake and air filter 6.2 to also measure from the middle of their crank.
.The air filter does not sit on the HMMWV intake manifold, there would be no room for it.
That C4 engine is rather anemic at 235HP would not be much of an upgrade, I was wondering why it was so cheap.
I am of course biased but if you are going to spend a few more thousand dollars I would install a Duramax and have and one in the wings.Another question I ask myself is should I put a LS in even if it cost a few more thousand dollars.
Yes, that pic is with the 2” body lift.Does the picture you include have a body lift?
