m1garand_man
- 0
- 0
- Ft Wainwright / AK
It turns out that the head on the same bank of my 6.2 which was emitting a cloud of oil and fuel smelling smoke on start up was cracked in each of the middle two intake valves.
The leak was so small that I didn't notice coolant burning at the rate I experienced the last time I had a cracked head so they must have been small cracks indeed. My question is if any of you who ended up finding out you had a head cracked in this manner experienced fuel and oil smelling smoke clouds on start up that cleared up in a few seconds after running.
The reason I am asking this is because I am waffling on whether or not to re ring my pistons and re do the bearings on the rods and crank. I am running out of $$$ for this project and am trying to get confirmation for this fault/symptom to better determine whether or not doing the re ring an re bearing is a waste of money or not. I haven't experienced a loss of power or rough idling until the head cracked which was about two weeks before I tore down the top end of the engine.
