Will this work?
gimpyrobb
dumpsterlandingfromorbit!
27,786
752
Cincy Ohio
The winch is the same. Mounting brackets, pto and driveshaft are different, I'd bet since its an automatic trans.
rosco
30
Delta Junction, Alaska
Get a picture of the mounts on the 135/211. They are not bad to make out of 1/2"x6". I have made them. They do use a shouldered bolt for mounting into the ends of the winch. Again, you can make them, if you don't have them. There are two 1/2" x2"x6" spacers, at one end of the two mounting brackets. The frame & the front bumper is long enough for the winch to mount. It does not use frame extensions, as does the M35. so you are ready to go. The PTO mounts on the T-case, but it & the drive line is straight forward. I like the winch controls in the cab, far better on the 211/135, the on the M35.
Lee in Alaska
