willys L-134 engine ID???
mikes47jeep
13
North East PA
Hi all
I found a great junkyard find
It’s a Willys L-134 complete fan to flywheel, and oil pan to carburetor with brown bakelite distributor cap
But what I need help with is identifying what year this engine is serial numbers
On top of block behind water pump
2 (that’s right 2 and just 2)
In small oval behind oil filter
MB 628776
On lower passengers side of block
638632 W5A NI-CR
I can’t seem to find any info on serial numbers so I can’t tell if this is a WWII engine or post war, either way it’s a jeep engine
best regards
Mike
paulfarber
20
Gordon, PA
MB 628776
The oval pad behind the oil filter is where the factory stamped the SN of the engine, to match the SN of the frame and chassis.
You have to many numbers.. jeeps were roughly sequentially numbered and they did make a lot, but not 628,000+
So you might have MB 62877 (thats a pretty early SN) my Oct 22 1943 Ford GPW sn is only 72,000 -ish.
Post it over on G503.com is Military Vehicles, The WWII Military Jeep, Parts, Olive Drab and All Related Things. and see what they say.
Bob H
160
the casting # 638632 W5A NI-CR is a WWII Willys block
the S/N starting with MB indicates it was for an MB
The build date is generally stamped on the bottom under the oil pan gasket.
gmccckw
netherlands, breda
MB 628776
Your discription is wrong. Willys started with serial 100000 and build more than 350000 jeeps during the war. But also build engines for gensets and other powersupllies. This engine is from 1945 and surely wartime. Date of assembly can be seen on the underside of the engine block, after you removed the oilpan
