- 522
- 44
- 28
- Bishop, California
My thanks to KATAHDIN, M16TY, GRINGELTAUBE, DOGHEAD AND XTSIX for helping with suggestions to removre sliding clutch key for winch.
I chewed off 25% of one key and mangled the end of another (se e pictures)
The problem I have now is that after replacing all seals, and all bushings-bearings, drag brake pad, and gaskets I am leaking gear oil at both ends of the drum from what appeares to be the new drum seals or the seals on the end case and worm gear case. Also a drip or two from the input shaft seal.
I measured the shaft diameters to make sure I was within spec. I also measured the worm gear shaft for the seal. I got the kit from a reputable MV seller that many SS'ers have used . I used GL5 gear oil. The seals were pliable and went on easily. Not sure what I did wrong?
