winch disassembly
dropaduece
harpers ferry, wv
I have decided to freshen up my winch and have reached a snag. It is just about completely disassembled. I am having trouble figuring out how the spool and shaft come out of the housing. The worm gear is out yet can't get the bull gear off or the shaft that its attached to out. Any advice. Thanks.
Seth
dropaduece
harpers ferry, wv
i checked manual Tm 9-2320-361-20.
i did not see any detailed information on winch disassembly. There was a bunch of diagrams for the rear winch.
any other manuals i can check.
seth
1,191
There is a winch parts TM. Look for it in the TM section(under resourses). TM9-3830-206-34P
dropaduece
harpers ferry, wv
what i am really hung up on is how to remove the shaft. On each end of the shaft there are two rounded keys, that sit into keyways. I am assuming they come out, yet i had a hard time getting them to budge. each time i tried to grap them i left indents on the keys themselves. i did not want to f them up too much. if they are indeed supposed to come out, let me know and i will try again. thanks again guys.
seth
301-922-1100 cell
1,191
They do come out, and you most likely will damage them removing them.(I did) I just replaced them with new keys from the hardware store.
m16ty
227
Dickson,TN
:ditto:
They can be stuck pretty good.
If you have removed the dog side and the drum the gear and shaft should slide right out. There is really no reason to remove the gear from the shaft unless you are replacing one or the other.
