Green Dog
- 1
- 3
- Niceville, Fla
Tore winch down due to jumping out of engagement at winch. Yoke does not slide on shaft without tapping pretty hard with hammer. No corrosion present. Seems to be an issue with the 2 keys inserted on shaft. Machinist looked at it and said you should be able to freely slide yoke into locked position by normal pressure by hand. I guess I need new keys. Any thoughts? And where to find new keys? Also, what amount of gear lube is to be installed in the engagement housing?
