Is there a service manual available for the 20,000 lb winches? I haven't used the winch on the front of my M51A2 as I don't have cable yet, but the drum clutch lever is hard to move, takes a hammer to knock it in and out. Also the drum lock knob will not pull out to rotate the 90 degrees.
I know there are two oil resevours, one on each side of the spool. The one on the drive shaft side has a low side plug, in line with the drive shaft. Is this all oil that's put into this side? I ask because the opposite side has the side plug way up high, is this the oil level of this side?
