Triple C
- 3
- 0
- NAPOLEON MO
The winch on my 925 is not functioning. I have read the tm's searched the threads and found lot's of great information. When I took the plate off of the tower in the cab, I found the cable that engages the PTO unhooked. I suspect it was unhooked because of a different problem because when I hooked it up, it still didn't work. I had a hard time getting the clutch to engage but the threads helped. I tapped the clutch lever and got it to move down toward the frame rail, about 3 inches of movement. Still didn't work so I looked under the truck at the pto found the cable is way out of line with the shaft it hooks to (see photo.) Can anyone tell me by looking at the photo if it tells you anything? I am thinking I need to disconnect it and see if I can get the pto shaft to move in or out. If I can get that done it is probably an alignment issue right?
