Winch on M1009
cfish
Eastern/NC
Are there any provisions for mounting a winch to the CUCV m1009? If so, are they in the TM? What winch size would be appropriate for this vehicle?
1,808
There are provisions but the Gov't and GM were not aware that they installed them. A framework could be fabricated that pins on where the lift shackles are! Easy on, easy off! No permanent truck mods and useful. My opinion is that a CUCV should have no less than an 8000# winch.
rnd-motorsports
Evart,Michigan
If your truck is still set up with the 24 volt starter then the jumper socket will be 24 volts you can change the leads that supply the jumper socket and put on the front battery and then use it !
Oldsouthernboy
Jacksonville, al
I installed a Hummer hydralic take off winch rated at 10,500 Powered off the power steering pump. I used the shackle mounts as a base of the mount and the hummer mounting plate to hold the winch. works like like a charm now I need a excuse to get stuck.
Hogg
Ardmore, OK
If you're looking for ideas check out Simoncrks avatar, he built a mount and used the lifting shackles to bolt to.... Works really well and looks good too
I built a mount that fit into the brush guard,. I used a 12k warn winch, It made the front of the truck seem heavier and handle funny. So I took it off. then mounted a old rear hitch up front between the tow points and the lower part of brush guard, That way i could keep the front weight down and put the winch up front wen ever I went Wheeling.
1,808
Could always source a 28V HMMWV winch and just pipe it right into the exhisting slave port..
