- 231
- 179
- 43
- Oahu, Hawaii
My winch was jammed up and didn't want to engage so I decided to rebuild it. Truck is a 66 M35a2 was an M109a3.
After getting the winch off and taking out the brackets and hell of a bent up bar with a pipe wrench, I finally got the selector side off I've been trying to figure put how to get the PTO driven side with the gear off, but no success. I have the TM that shows all the parts with names. But it doesn't show proper assembly order. I also noticed on the selector side there is what i think is a brake pad attached to a T with a spring on the back. However where all the other trucks have the lever mine has a grease fitting. I still cannot get the PTO side off. Do I need to take the gear that looks like a screw out first? Im Also going to need another bar mine is bent to hell. Has anyone used thicker metal plates to replace the bent support bars?
Sent from my LG-H918 using Tapatalk
