winch wont turn on M923---
gem1410
44
TOMS RIVER NJ 08527
When I placed the winch levers in operational positions the hyd oil flowed and the winch would not move in either direction--The inside of the winch looks clean with nothing broken--the spool does move with the lock pin pulled but the main gears will not turn--any ideas--thanks George
1,179
Pull the band brake cover off. Your band brake may have rusted stuck.
Just a good hit with a hammer and drift should fix that(if that is the issue).
Seen this a few times.
MtnSnow
14
NSL, UT
Follow the troubleshooting from Work Package #0059 from the TM 9-2320-272-23-1 which starts on page 607 of the PDF
juanprado
2,922
Metairie/La (N'awlins)
Thanks for the tip ~ Doghead!
Does the gasket on the brake band cover plate just act as a dust and water shield? Does it require RTV or sealant?
Would it hurt to hit the assembly with aerosol brake cleaner?
1,179
I think it just needs occasional maintenance.
