hoopsoft
- 0
- 0
- Purcell, OK
So I got a winch from a guy, and everything else off another m35a2, PTO, drive shaft, brackets, etc.
My winch looks like the normal deuce winch but the one piece I was missing was the winch yoke to PTO driveshaft yoke U-Joint.
I look up what you guys are saying the whole spicer 5-153x and go the parts store with my yoke, and it doesn't even come close to fitting... What fits my winch yoke is a spicer 170, alot smaller.
In doing my research the only thing I can come up with is maybe this came off a m211 or m135?
If this is true are the worm gear shafts the same size and could I just get a different yoke from a m35a2 winch...
(my shaft is a 1.25 diameter.. smooth (no splines), 5/16 sheer pin hole)
