- 34,012
- 1,806
- 113
- GA Mountains
I wanted to start a conversation on the above. I've got the FM 20-22 which is a Field manual on recovery. It has lots of basic information and lots of more complicated information on the subject. rdixiemiller says he might be able to get this thing copied over to PDF where it can be downloaded by all. I have many a story on right and wrong ways to recover stickage. I just stumbled across this little tool and thought all y'all might want to check it out. http://catalog.thecrosbygroup.com/Calculators/Calculators/snatchblockrigcalc.htm
Its a pretty cool program that shows you the force on a snatch block depending on how its rigged. For example, if you are rigging a snatch block off of a tree and using it just to change directions of pull, you are doubling the amount of pull in the blocks hook. Of course everybody knows that when you rig a snatch block or a winch chain with a hook, the open part of the hook (throat) goes up! You didn't know that? If you didn't, the reason for that is safety. Should the hook open up (bend under pressure) it would be forced towards the ground should it let go. Here's another link wort reading.
http://www.dodgepowerwagon.com/glovebox/snatch.html
Folks die from this so lets talk a bit, learn a bit and share a bit on the topic. We can all learn from anothers mistake. I'll post more but lets get started!
