RE: Re: RE: Window crank / door handle disassembly
To reiterate, preventively, DO NOT remove the door latch or window crank mechanisms unless they are completely FUBAR. I am a fairly small guy, 5'-9", 160 lbs. My drivers side door latch WAS fubar and I had to R&R it. In a stroke of dim brilliance, I thought removing the window crank mechanism (technically known as the window regulator) would make the R&R of the door latch easier. WRONG! Do NOT undertake any task which requires jamming your forearms through the door access hole and trying to remove, repair or replace anything inside the door unless that item is totally inoperative. The window regulator is powered by a coil spring and will strike like a rattlesnake with no notice. Unless you are a 90 lb weakling, there is no way to get your forearms up inside the door without slicing them to ribbons on all the razor sharp braces and reinforcements that are welded inside the door. Squirt lubricant up, down and sideways, crank the window up and down and lubricate every moving part you can see, but take components out only if absolutely necessary! The TM procedure makes replacing those parts look like a walk in the park, in reality is is more like a low crawl over razor edged barbed wire!
