Window Regulator Clip Removal
rboltz
Hershey, PA
I give up. How do you get the clips off the glass regulator so you can lift the door glass out. You can't see them much less get tools in there. I tried moving them with my fingers and a small screw driver but no luck.
foxtrk2
foxboro ma
got mine off with small pair ofneedle nose vise grips ,not easy but doable just dont squeeze them so tite they snap in half just grab and rock in circular motion till they slide off sideways foxtrk2
rboltz
Hershey, PA
Got them off
I got a small mirrow and put velcrow on the rear of it and the inside of the door. That way i could have both hands free and see what I was doing. Then I got them off by lifting the "lock" on the clip a bit. Before, I just could not see what was back there. I hope they go back in easier then they come off!!
M-37Bruce
59
Midlothian, VA
Yeah, wait till you try & re-install them, might be a good idea to have some spares around! I used crushed a total of three. So I now have one spare. :-?
rboltz
Hershey, PA
I have 3 left from my M-715 project. Need at least one more. They were common at the auto parts places like NAPA but no more. They were used in many older vehicles, not just MV's. I took a new one to NAPA and you always get the same response "year, make, model" please!
Memphis has them and I think Midwest also but expensive for a one time $.50 clip.
M-37Bruce
59
Midlothian, VA
Sid was a dealer,(actually a prince of a person) Ace Surplus, he passed away awhile back. Someone, another dealer in Texas bought his entire inventory, his name escapes me now, but it'll come to me. :cookoo:
TxRider
Texas
I always just use a small screwdriver to push up the tab in the middle of them and they pop right off, same when putting them back in.
I ended up with two extra to save that I found laying loose in the bottom of my doors.. ;)
Mike_L
9
Marion, IN
Like TxRider said, I use a small flat blade screwdriver to pop them off. For me, putting them back on is another task entirely but with patience, not too bad.
Off the top of my head, I believe Brent Mullins bought out Sid Beck's inventory. Check over at G741.org for confirmation.
199th mp
Centralia, Washington
window regulator clip
this part can still be bought today, and auto glass shops that have been around a while may have a box of them on hand. they were used on lots of chrysler and jeep vehicles for years, and are still sold by cr laurence co, as part #SC3315. get a box and spread them around to your friends, they're not expensive at all.
rboltz
Hershey, PA
I agree. They were used on many vehicles and were available from auto parts stores on the "small parts" rack. I think the number is SC3314 instead of 3315? 3314 may also work, just a different way to clip on.
rboltz
Hershey, PA
Well, we are now putting the doors back together. I tried pushing the new clips on with my fingers with no luck. So, two pair of vise grips to hold the regulator arms tight against the window frame "slots". Started them with my fingers and used a drift to tap them on. PRESTO!! What helps is the smallest vise grips you have so you have room to work, I used 4" mini's, and having the regulator at just the right height to give clearance. I was not looking forward to this but it was better then the removal.
M-37Bruce
59
Midlothian, VA
When I did mine, one was a breeze, the other one the drivers door was crazy difficult! I think i did the mini vice grips as well?
