Windshield Frame Seal Orientation
Tinwoodsman
75
Comfort, Texas
When the frame seal is installed, does the convex side go toward the windshield frame or the front of the vehicle?
Tinwoodsman
75
Comfort, Texas
Thanks G. I have attached a picture of the seal I removed and it is identical to the new one. So the convex side will go toward the windshield frame. Thanks as always.
EMD567
Driver for the Ga Mafia
47
Aiken SC
Good luck. I purchased two new windshields for my 814. After installing the windshield, I found that the rubber wouldn't let the frames close so that I could latch the windows.
I had to change the rubber so I could get the window closed. Rode in the rain the other day, and no leaks( at least around the rubber) :mrgreen:
Jake0147
Panton, VT
I asked about this previously an was given good advice. The windows will be about half a tug short of exploding in your face by the time you get the latches latched. The new gaskets take their new shape quickly. and that issue goes away before you know it. Park with the window facing the strongest sun helps speed the process.
gringeltaube
Staff Member
2,477
Montevideo/Uruguay
Yes, GOOD luck!
Depending where they come from (Newstar?) it can happen that they won't close at all no matter what tricks you try out (heated the rubber seal all around, lubed with silicon grease, etc) And if you finally managed to get it latched - come back next morning and check if glass is still in one piece....! Don't ask how I ............
BTW, just found this one: https://www.steelsoldiers.com/threads/windshield-rubber-install.19367/#post198144
G.
73m819
319
gainesville, ga.
WOW, I learned something today, that the front windows do in fact SEAL, I always thought rain gear was part of the BII for the driver
gringeltaube
Staff Member
2,477
Montevideo/Uruguay
:funny:
Yes, and no, depending how many hours you are willing to invest.....LOL
I got the cheap-chin aftermarket WS assys and it took me a whole weekend to get them working properly AND sealing! That included complete disassembly, cutting/ rewelding/ reinforcing the frame, sandblast, paint, installing new ( this time correct size) glass, etc, etc.
Some pics, below....
G.
roady
Greensboro MD
I just bought a set of the aftermarket ones.... I hope they are not to bad off.... I always seem to read this stuff a day late...
Tinwoodsman
75
Comfort, Texas
I started this thread about a month ago to prepare to install my windshield rubber seals. Thanks to responses many of you and past posts by Barrman, Dabtl, Gringeltaube and Gimp, I got the info needed and installed the seals today. It took me 10 minutes per window once I had everything together and I am very pleased with the results. Here are some basic tips I can pass along.
- Start with smooth clean frames and make sure the groves are clean
- Find your self a butter knife with a rounded edge
- Use a glove on the knife hand
- Use dish soap on the seal prior to insertion
Start at the corners and lay the outside face of the windshield up. Insert the inside edge of the seal on both sides of the first corner and seat the outside edge about one inch on each side using the thick side of the butter knife rounded edge. Use the knife to roll the edge outside lip of the seal into the groove. Do the same on the other corner and work toward the middle of the bottom windshield edge. Finish with the sides and voila, you are done. The photos show the butter knife I used (don't tell momma) with the rounded edge with the blade being thicker on the upper side. The finished product and a corner close up. Good luck and I hope this helps.
SasquatchSanta
Northern Minnesota
For future consideration here is a modification that won't leak.
The frame in the attached pictures is for my M37 but the principle is the same.
Fed up with the rain and Minnesota winter coming in on me I went to a shop that builds cab components for heavy equipment and had a piece of sheet metal cut. They also supplied two pieces of cut safety glass and the rubber molding. The cost was $200.00.
Prepping the frame and welding in the sheet metal panel was time consuming but worth the effort.
It's not original but it's an option that works.
