Windshield Replacement
mattrains
Flowery Branch, GA
When I picked up my HMMWV from GP it had a cracked drivers windshield. I've called around and looked online and no one will replace an H1 windshield? Even the Civ version?? Anyone with experience in this? Should I just get a piece of glass cut and put it in myself? I would assume it's the same process as a Civ H1, what are they doing when they bust a windshield?
Sorry if this is a noob question but they last thing I thought would be a hassle is the WS?
papakb
1,184
San Jose, Ca
I had mine replaced years ago by a local glass shop. The job is pretty easy but you need to make sure they have the right thickness in stock. There were different thicknesses depending on the model of your truck. Just remove the retaining brackets and push the old one out of the frame. Remove the rubber surround and take the piece to a glass shop. When I reinstalled mine I used silicon sealer around the glass itself and between the rubber and the frame.
BTW, We're here to answer noob questions. because we learned a lot of this stuff the hard way doesn't mean everyone has to.
Kurt
Mike82ndABN
10
Tampa/Florida
I know this doesn't apply to your cracked windshield, but to anyone with a pretty fogged up dull windshield... I used rubbing compound, then polishing compound, on a buffer for about 10 minutes and was able to get the windshield to clear up a lot. I finished up with a ceramic stove top cleaner (very fine abrasive). My driver windshield looks like new and the passenger side is about 95% perfect, I couldn't see through the passenger windshield at all when I bought the truck.
Retiredwarhorses
4,135
Brentwood, Calif
If you can undo like 10 screws and remove the retainer ...they just pop out. You can have a new piece done at any glass shop. Install is reverse...but done force it near any edges...lube up the seal with wd40.
114
NH
I am doing my passenger side this weekend and I will let you know how it goes. I have a new piece of glass and new seal.
