Windshield weather strip question
Jake0147
Panton, VT
I've managed to find several posts with tips on how to install the weather strip, but I can't seem to find anything here or in the TM that suggests what direction they are installed. I put them in with the "extra lip" facing out, just as the originals were removed. But they seem very very stiff. I almost feel like I'm going to break the glass. So I turned one around. It shuts just nicely, but doesn't seem to sit right with the window shut, and I think it's backwards. Can somebody confirm that the "extra lip" goes towards the front of the truck?
hole
Alta Loma , Ca.
I installed mine with the largest lip facing forward ( as it was when I took out the old ones) they were alittle stiffer but broke in in no time. We open our windshields alot in sunny so cal so they get alot of use. Hope that helps
Jake0147
Panton, VT
That does help, Thanks. I thought that way made more sense, but man are they tight... Oh well, salting season starts early up here since the flatlanders have taken over. They'll have all winter to settle in. :cry:
vtdeucedriver
Vermont
Welcome to one of the worst jobs on those trucks!!!!!!! The lip foreward is right, put the back part in first at the bottom and then tuck the fwd lip in, get the bottom in 1st then the sides. I use a small flat screwdriver to tuck it in.
hole
Alta Loma , Ca.
I found that a small amount of soap mixed with water was very helpful too, lubed the gasket just enough to be able to push in with screwdriver without tearing
Jake0147
Panton, VT
After about ten minutes of frustration, I actually found a screwdriver that was just worn enough, just sharp enough, just wide enough, and got a technique that worked pretty good. It got quicker each time... Stubborn nature made me install the gasket dry. By the last time I used lube. I think it went in easier without the lube. I mean it slid in easier at first with a little soap, but I couldnt' get the top of the "T" into the slot just right. It kept squoozing around the screwdriver instead of tucking into the slot. I had to install with the screwdriver, then go back and "fix" the install with a putty knive and the screwdriver.
hole
Alta Loma , Ca.
For the most part , a worn flat blade screwdriver worked on 80% of the job for me. For reasons I cant explain a putty knife worked better on the last little bit. I actually thought removing / reinstalling the window frames was the bigger pita , at least for one person.
m35tech
Westerville, Ohio
weather strip 2 cents
I thought I would add my 2 cents, depending on its use, good 3m weather strip adhesive , and when putting in the weather stripping either let it warm up, put it in a box with a heat lamp on it , helps it be more pliable and or use a hair dryer from the wife, this also helps the adhesive set as well. or to remove the old adhesive and weather stripping....
