Windshield wiper and washer repair
antennaclimber
1,057
State College, PA
My M1008 seemed to have an issue with the washer and wipers, the washers would not squirt and the fast wiper speed would not work. Sometimes they would and other times they would not. The low speed seemed to work just fine.
Thinking that the wiper motor assembly was bad, I changed it out and things seemed to work. Today, only the low speed worked, no fast and no washer. So now I questioned the switch in the steering column. Not wanting to delve in to that repair, I wanted to prove that it was indeed the problem.Using a clip lead and connecting the PINK wire to ground, the washers worked. Connecting the clip lead to the PURPLE wire on the wiper motor to ground, the fast wiper mode worked.
Looking at the schematic for the wiper motor, the washer is controlled with a relay that has +12 VDC on it when the key is in ACC or RUN. The PINK wire is the switched ground command to turn on the washers, the LIGHT GREY wire is the +12 VDC. Using an ohmmeter, I found that there was no ground coming from the switch on the column to the washer relay. The fast speed also was not getting the ground command to run the wipers in the fast mode.
There is a connector on the steering column for just the wiper motor control. 5 wires control the wiper and washer commands. I removed the panel under the column and there was the connector in a very easy location to see if the switch is defective.
Upon disconnecting the connector, it appeared that the connections to the washer and fast wiper speed were not right.
The washer connector was spread open some and was not making a good connection with the connector to the switch. A small wire brush cleaned up the column side of the connector and a small connector file cleaned up the vehicle wiring harness side of the connector. I also used a very small screw driver to tighten the connector contacts.
After cleaning all of the connector contacts and making sure the connector pins were seated properly, both the washer and fast wiper speed worked!
