- 3,569
- 3,474
- 113
- Brooklyn, NY
Driver's side windshield wiper arm does not park at the 4 o'clock position but hangs at the 5:30 position when the motor swings it back and forth it only traces an arc from 8:00 to 5:30 with me sitting in the driver's seat looking out the window. Passively, when the motor is off, I can push it to the 4 o'clock position, and it feels loose ( and the passenger side wiper arm does not move). The passenger side operates correctly With the motor on and cannot be moved with the motor off. The motor operates correctly.
I do not see how to remove the windshield wiper from its post to see if it is loose between the arm and the post or if it is loose somewhere between the post and the motor.
I would like to know how to remove the windshield wiper arm. I would like to know points of common failure. I would like to know how to view the internal structure. I believe this is all complicated by the fact that I have a hard top.
Thanks in advance
T
Thanks in advance
T
