Wiper blades and arms for a Deuce
Oldgrunt
Lancaster Ohio
Hello All
I'm in need of some new wiper blades and arms for my Deuce. I went to the cross referance guide, but didn't see anything. Does any one have a part no. for NAPA or Advance Auto?
Old Grunt
ems4ty
restricted/ca
Check out Saturn Surplus on the web. Jay usually has those I believe. I think he also sells the conversion wiper arm that accepts a standard wiper blade that you could get at your local auto parts store. I have the upgraded wiper blades/arms from him and they seem to work very well.
steelandcanvas
85
Southwestern Idaho
Re: RE: Wiper blades and arms for a Deuce
I did the same thing and never looked back. The conversion kit is the way to go.
jim-m35a2
Michigan
I installed a set of Saturn upgrade wiper arms and blades on mine. The kit is 19.50 per one arm and 10" blade. I had to losen the set screw on the back of the arm and cut 1" off the shaft so the blade would not hit the sides of the windshield frame. I used the original knurl and mounting nut to secure the arm on the wiper motor shaft. I also painted the arms black. Shipping was 8.31 for 2 wiper kits and a windshield washer kit.
Jim
________
Magic Flight Launch Box
emr
25
landing , new jersey
You mean U can see out in the rain with those, ???I just got in from the rain today with the deuce, it gets just as wet on the inside, they need an upgrade that has a wiper on BOTH sides of the glass... :shock: ...Randy
jim-m35a2
Michigan
Yep, drove mine home from Indy and got a face full of rain. Stopped and got a roll of paper towel out of the chase car and plugged most of the gaps. Both wipers had half of the rubber torn loose from the blade and were flopping about. At least the plastic wiper motors worked :D
Jim
________
Druidism Forum
emr
25
Most of the gaps,,, rofl ,Ive been there so many times, but your knees still were getting soaked...It seems the wiper motor on my side always fails... even on my civy stuff, why is the drivers side cursed?
