123mack
- 11
- 18
- Jemison, AL
I've found two air wiper motor kits which I can't identify. There is a tag in the box which lists the manufacture as US Hardware Supply and the NSN is 2540-01-303-0600. The motor is shorter, thicker than one found on the 2.5 and 5 ton trucks, and the mounting holes are spaced differently from the originals. The wiper arm shaft is also larger. I've tried a couple of different indexes, but cant determine the correct vehicle. I was thinking on making an adapter to use these on my M35A2 and using the take offs on my wrrecker project. Can anyone help me identify the correct vehicle for these?
