wiper question
junkyardog
wakefield new hampshire
i purchased the wipesr and arms that some one posted the numbers from napa. they are correct. but my question is there a better wiper motor or arm or set up that is a lot more rugged, this dont look like it will handel snow. why is that hole in the frame so small.i would like to put a motor like the old milk trucks had. can that hole be bigger.
CGarbee
550
Raleigh, NC
If you want a really nice heavy duty wiper that can handle snow, you might want to consider some units similar to what I mounted on my Cummins powered M37... Granted the M37 is a 3/4 ton, but it uses the same inner window frame... Page on my website details instalation and has parts numbers (follow the link on the page to the PDF from United Technologies for the tech info including the 24 volt version) and instalation instructions.
http://www.garbee.net/~cabell/electricwipers.htm
Good luck.
ida34
32
Dexter, MI
Check under tech articles. There is a write up on the upgrade. I also did a post about 6 months ago on it. I forgot the numbers but I took the napa numbers to my local parts store and they crossed them to an anco number. I used anco stuff for my upgrade and it is much better than the original stuff.
cranetruck
75
Meadows of Dan, Virginia
junkyardog
that looks like a very good idea. im going to try that. did you drill a 5/8 hole right where the old one was. or higher. does it interfear with the glass. thank you. to my other reply i have left the slip i got from napa at work. i will post them buy this weekend. i will include part # and prices.
