wipers on the m1009 not working right
84cucv1ton
New Jersey
they were fine. i had the key in the on possession. was hooking up something to the fuse block. heard some strange sound from the column itself. think i might have fried something. :-x
now only work in high and does not return back at all.
any ideas what i could have done?? hope i dont need to take the column apart. thanks
84cucv1ton
New Jersey
after some reading and testing. some how i fried about a 10" section of wires in there. not sure if i should take it apart or get another column. been told the column use a lot of cheap plastic that breaks.
319
Lieutenant
58
Michigan
Take it apart, it's quite simple, just digitally remember (camera) how it came apart because the TM has real crappy illustrations. In addition to your basic metric hand tools, you'll need a steering wheel puller, lock plate depressor tool, and Torx T20 (iirc).
84cucv1ton
New Jersey
will be doing this over the weekend. got the tools from a friend. never took one apart before. was told it a pain. see ho it goes mike
twright
Rockmart Ga. 30153
Most of the time if the wipers will work on high or low and will not park it is the wiper motor that is going bad all the controls are in the motor as far as parking not in the switch
3M35A2
2M35A1
1M1008
2M1009
M105A2
1 Gama Goat
HardCorps79
Kansas City, MO
If you already messed with the elements in the steering column and it's still slow, and won't park, it sounds like the motor. No need to check anything, necessarily (some may disagree). I'd order the new wiper motor and replace. I'm often loathe to spend an unnecessary dime, but sometimes an extra couple bucks is worth getting rid of a pain in the A**.
