wipers working on high only and dont return
84cucv1ton
New Jersey
Cleaned the connections and the grounds. still doing it. that was all it took on my 109.. any ideas? hope i didnt fry something thanks
cpf240
Free in Northern Idaho
You could use the later-year wiper motor that doesn't have the built in washer pump, that may allow it to run better. You'll need to add a pump for the washer then, either an in-line or get a later washer tank with pump built in.
Iceman3005
97
Holt, MI
The stock one should be fine, when I replaced mine the wipers worked a lot faster on low and super fast on high. Remember your wiper motor is probably the original motor, so it lasted 20 plus years. I would say it is a pretty strong motor to have lasted that long!
Gunzy
66
Roy, Utah
If those are 12 volt you should be able to get an A1/Cardone rebuilt one at an O'Reilly parts store.
1,808
I can't speak intellegently for wiper motors but for power window motor, I won't go anywhere but NAPA. Much faster.
