Wire #11 on Deuce
196thprober
12
Northeast Michigan
Can anyone tell a stupid FNG what wire # 11 in the Deuce main harness is for? It had a short/battery drain, disconnected it, have checked everything, seems fine, can't tell what is not working. I'm not smart enough to find it in the manual. Thanks
wdwjr
whiteford maryland
196thProber
If you have not made it to the OD website wire no 11 says it it Ignition switch feed or magneto ground ( LH ) Hope this helps and good luck!!!!
David
196thprober
12
Northeast Michigan
Thanks to all of you for the great advice! Have run some things down, OD Iron site/link was great help, still not sure exactly what the deal is but we are on it thanks to you. Can't make the diagram by Jimm1009 into a readable page, but it doesn't matter; thanks again!
