Thanks for the info guys. I have a good assortment of fusible link wire on hand so replacing them isn't a problem. I had just never noticed that the different splices for the fusible links had different numbers cast into them. I've replaced three of the links so far, two of them had patch jobs on them and the one that goes to #2 generator was fried.
Once I locate a replacement starter relay and another battery, I'll be ready to test the electrical system. The parts houses don't have the relay, but Chevy says they can order it on Monday and have it Tuesday. If it checks out ok, I'll be ready to actually try to start the engine. (Might just bypass the missing relay and try starting it anyway...)
luapmoon - Great link!
It's been added to my drop box. Spent 26 years in the military working on vehicles and that's the first time I've seen that list!
Smitty
1031 - Work in progress
1956 Chevy 3100 4x4, 383 stroker, TH400, 203/205 doubler, 14 bolt rear (w/Detroit), D44 front (Still open), disc brakes on all four, 35" BFG's
Located in Crestview, FL
