Wires for horn on m1009 ?
Jonas
Stockholm/Sweden
When i got my truck it had a separate button for the horn, no idea why... i guess the original horn was taken out sometime back...
measuring the power on the horn fuse i see that it has 12V power, and now i wonder if anyone know what wire coming from the steering wheel that connects to the horn ? i got 2 cables inside for the new horn, but i rather not use that stand-a-lone button but use the one on the steering wheel instead :)
also looking for wire colors from the wiper switch :)
THanks alot all!
Warthog
224
OKC, OK
There is only one wire in the steering column for the horn. It is black. The horn grounds thru the column.
There are 5 wires for the wiper control and 8 wires at the wiper motor.
Here is the stock wiring diagram.
These are available in the -20 and -34 manuals.
Righ click on the thumnail and choose "Open Link in New WIndow"
Jonas
Stockholm/Sweden
Thanks for the reply, ive looked at those and i check whereither it gets grounded when i push down the horn button but its not :/ i use the check connection part on the voltmeter and it just displays numbers instead of giving me the beep for connection, guess its bad ground.
I had problems identifying the connector this ground wires goes into when it comes from the button :( anyone able to take some photos? :(
Also, how much volt is the horn made for ? i send in 12 volts and it just clicks from the horn... sometimes it beeps loud and clear but latley just clicks... there are new wires to it and it grounds to the chassi... ive added a new ground for it so grounding shouldnt be the issue...
dependable
187
Tisbury, Massachusetts
There is a diode on the back of horn relay plug. I believe it is part of radio noise suppression. when it goes bad, I think it grounds out the relay. Cutting the diode wire may solve the problem. It worked for me.
tankie88
Redruth,Cornwall,England
My horn never worked since i had my M1009.The relay clicked and that was that.The nugget who had it before me ran new wires,horn and a new push button.All i did was remove the wires off the old horn and cleaned the connections and the original worked no prob.Now it all works.
Red_506
Roseville, CA
I still need to procure a horn as some knuckle head in the line before me completely removed the horn. Although my relay works, I can hear it click when I instinctively try to beep at non-driving morons.
erniemigi
Amelia, ohio
i had to actually install a new horn button, you can push on the original button and hear the relay click but as soon as i connect the wire to the horn it just starts going off non-stop (made a few neighbors mad at me, ohh well) any idea about this one
cpf240
Free in Northern Idaho
Probably a shorted diode on the horn relay.
