coachgeo
- 3,404
- 113
- North of Cincy OH
For those that have dealt with wires behind dash panel.... am replacing turn signal/headlight Stalk. Pulled front panel to access plugs to unplug it. Plugs are too large to pull out of access hole in dash floor without some magic. There appears to be a plate bolted onto floor of the cavity behind the dash panel. This plate appears to slightly cover the hole the wiring goes up into that area thru. My question is will unbolting that plate open more access to the hole the wires go thru? Not sure what that plate is in there for.
Thank you in advance.
Update: On second look today with better lighting..... the piece bolted into the floor of the cavity does not cover the access hole at all. It is very close to its edge... but does not cover it.
