Wiring Diagrams
Looking for the thread about the wiring diagram for the Deuce.
I am pretty sure it was in the old forum and did an unproductive search there.
The above link from Jeff (Junkyard Wars Crusher) does not work.
I have the diagram I just don't want to start another thread.
I have covert reasons for this. Can you say huge banner of wiring diagram?
avengeusa
MI USA
i am also looking for the diagram, i have charging issues..... like not charging, and i have found a wire off..... labeled 2, in the starter area, it has a large ring, like it should go to the solenoid on the starter
avengeusa
MI USA
thanks, I found it, it appears that the number 2 labeled wire is the charge wire from the alternator and goes to the starter solenoid to charge the batteries
when the truck is running i am getting no power from the alternator, cannot find a troubleshooting chart, it may be an internal alternator issue......
3 wires on it, one is ground, one appears to be the field, and one is the charge wire....
