Wiring Harness Modification
Tinwoodsman
77
Comfort, Texas
I am bobbing my deuce and am wondering what most people do with the rear wiring harness. I know I could coil the extra length at the frame rail or shorten the wire using butt connectors. Any suggestions or experiences?
rosco
32
Delta Junction, Alaska
You can take the plug apart, un-solder the wires/shorten it appropriately, slide the metal ID tags back too, and the job would be professional! It doesn't really take all that long, to do it right.
Tinwoodsman
77
Comfort, Texas
I was thinking of using butt connectors covered by heat shrink tubing. I do like the idea of reusing the metal identity tags.
KsM715
142
St George Ks
If you cut it please re-use the tags, youll save yourself or future owner any severe headaches should any problems arise.
Mine, I just looped the extra lenght. Quik and easy.
hndrsonj
Senior Chief/Moderator
377
Cheyenne, WY
Personally, I'd take the plug apart and solder. It is the best way, but a little more work.:driver:
