- 34,012
- 1,807
- 113
- GA Mountains
Todays order of the day is figuring out circuit breakers. I was studying the schematic and didn't find a circuit breaker for the headlights. The ones on the firewall are for the horn relay and the aux circuit. I ran out to the tractor and checked the wiring numbers on the breakers. Both were fed with wire 10. One breaker had wire 25 which is for the horn. The other had wire 37 which is unique to the tractor. It provides aux power to the semi trailers requiring 28V for interior lighting. This was exactly how the schematic shows it. Then I went to check out the pipeline. It had 25 on one breaker and 518 in the other breaker. 518 is for the flood lights on the pipeline. Accoording to the schematic, 518 is supposed to tie into 75 stoplight input. Oh well, its a little different. Then I decided to check out the front half of an M35A2 in the yard. It had wires 25 in one breaker and wires 74A and 74R in the other. According to my schematic, these are supposed to go to a fuel pressure switch. Do these fuel pressure switches look like circuit breakers and what is their purpose? Also, where is the headlight breaker? Maybe in the light switch?
