Wiring M818 Battery Switch
burt8921
Oklahoma City, OK
Alright, I have viewed hundreds of threads and can't locate one directly on point. My battery switch died and after some doing, I obtained what appears to be correct replacement but of course did not label or mark leads. Switch is a four terminal but only three leads to it, one of which is hot. I can wire new switch and get juice to start truck but can't kill it other than manually and when switch off, still sending juice to fuel solenoid I assume. Can anyone direct me to a wiring diagram for switch? Technical manual of no assistance. Any help much appreciated.
1,174
Is your shutoff solenoid manually opened?
Has your switch ever functioned properly for you?
burt8921
Oklahoma City, OK
Shutoff solenoid is manually operated. New switch has not functioned properly yet and I had really decided maybe this switch was not the right switch but thought I would explore here before getting another. Could not find a wiring combination with new switch that cuts all voltage off (i.e. - can start truck but when turn switch off, still have power to fuel solenoid). Truck is on farm couple hours from where I live so I don't get to spend a lot of time diagnosing it unfortunately.
