walkerbzz11
- 41
- 18
- Tennessee
I think that's the starter wire.Can someone tell me what this blue wire is for and where it plugs in? Thanks.
Forgive my ignorance, but what does it start? The truck starts fine I guess and it's unplugged...I think that's the starter wire.
Sent from my SM-S906U using Tapatalk
Oooppps!! I missed it had a connection on the end! Yeah mine have that too and are not hooked to anything. The other blue wire coming out of the box is the starter relay wire that kicks the starter on. 2 of mine had that clipped and had a ford starter relay botched in them. I removed all that and put it back to stock. I haven't tried to figure out what it might do but all mine are just taped to the harness behind the master.Forgive my ignorance, but what does it start? The truck starts fine I guess and it's unplugged...
Ok. We'll leave it for now. Thanks.Oooppps!! I missed it had a connection on the end! Yeah mine have that too and are not hooked to anything. The other blue wire coming out of the box is the starter relay wire that kicks the starter on. 2 of mine had that clipped and had a ford starter relay botched in them. I removed all that and put it back to stock. I haven't tried to figure out what it might do but all mine are just taped to the harness behind the master.
What wire could I install a kill switch on? The blue wire WWRD99 was talking about that goes to the starter? Thanks.That blue wire goes to a fuel pump on the M1010 models. The fuel pump is mounted on the left inner fender and pumps fuel to the rear diesel fired heater in the rear of the M1010. It is not used on other units and does not get attached to anything. I think it also is used on the winterization kit to heat supply fuel for the heating system. I only ever had 1 with that kit and it was in very poor condition.
Yes you can...it's easier to kill the ground to the relay under the dash...the 12 volt side ground.What wire could I install a kill switch on? The blue wire WWRD99 was talking about that goes to the starter? Thanks.
What if I want it hidden a little better?Yes you can...it's easier to kill the ground to the relay under the dash...the 12 volt side ground.
You can kill the ground and bury a switch under the dash...I don't like switches on power sides...to much possibility of failure.What if I want it hidden a little better?
Might do that. Gotta figure out which ground. Wiring ain't my specialty... Thanks.You can kill the ground and bury a switch under the dash...I don't like switches on power sides...to much possibility of failure.
I'm going to do the same with mine. There is a nice size void between the ashtray and glove box. If you remove the glove box, it will give you good access to mount a toggle to interrupt the start relay. Position the toggle so you can reach up from the underneath is what I was thinking.What if I want it hidden a little better?
Is that ground wire over that way or are you gonna reroute it over there?I'm going to do the same with mine. There is a nice size void between the ashtray and glove box. If you remove the glove box, it will give you good access to mount a toggle to interrupt the start relay. Position the toggle so you can reach up from the underneath is what I was thinking.
The relay is right above the diag plug...very easy to get to. The only metal one under there.Is that ground wire over that way or are you gonna reroute it over there?
The ground for the relay (black wire) goes into the harness. You just have to interrupt it with an on off toggle. Moving the toggle (extend the wire) to the other side of ash tray hides it from anyone looking up under the dash. Looked like a good spot to me that could still be reached from the drivers seat with a little stretch. 4 screws removes the glove box. take a peakIs that ground wire over that way or are you gonna reroute it over there?
Thanks. Glove box is out already for other work.The ground for the relay (black wire) goes into the harness. You just have to interrupt it with an on off toggle. Moving the toggle (extend the wire) to the other side of ash tray hides it from anyone looking up under the dash. Looked like a good spot to me that could still be reached from the drivers seat with a little stretch. 4 screws removes the glove box. take a peak
Will a 2 position 12v toggle switch work for this?The ground for the relay (black wire) goes into the harness. You just have to interrupt it with an on off toggle. Moving the toggle (extend the wire) to the other side of ash tray hides it from anyone looking up under the dash. Looked like a good spot to me that could still be reached from the drivers seat with a little stretch. 4 screws removes the glove box. take a peak
Is this what you're talking about? And am I missing the "plate" that these mount on? I just kinda stuffed the other plugs and wires up out of the way for this picture otherwise they'd be hanging there too.Yes. Pretty much any on/of switch will work. The black wire carries 1 amp or there about. Regardless, it won't be thrown while energized anyway.
