Wiring ???
wyliek
Chandler AZ
i was trying to add a liscence plate light today, b/c i got a written warning the other night about it. i wasn't sure where to start so i was looking on the fuse board to see if there was a slot. does anyone know of one?? wat are all the harnesses down there for? there are 2 about 1 inch next to the fuse board and one huge one just above the brake pedal, i also have another one next to the military accesory plug next to the transfer case shifter. what are they for??
73m819
325
gainesville, ga.
just mount a light, then run a wire from the tail light wire to the plate light, i dont beleave there is a fuse just for the plate light
ken
25
Houston Texas
There should be a purple wire with a black female plug on the end. This wire should be where the wiring harness splits between the tail lights. The same tail light harness was used on the civi GM pickup trucks. This purple wire is intended for the license plate lamp. Try looking at the drivers side frame rail. They usally tuck the wire around the crossmember above the spare tire mount.
mangus580
282
Western NY
If the purple wire isnt there, the brown wire in the tail light harness will give you the power you need. Me... I plugged mine into my trailer plug... got me inspected :)
mangus580
282
Western NY
The brown wire is the parking lights wire. so if you wanted your plate lamp to work with the trailer, you will have to split it. You can find that wire under the truck in a few places.
wyliek
Chandler AZ
no purple wire found, 3 wires going into each tail light, and 3 for each blackout LED
mangus, there are 2 harnesses going to the military trailer plug, i havnt encountered this before as i havnt towed anything yet, but is one of the 2 harnesses (which each contain 3 wires) for the blackout LEDs?? they both have brownish looking wires, but i guess it could be sand/ salt
mangus580
282
Western NY
unplug the two plugs, and test them with the lights on. Use a volt meter or test light. (I forgot, the forrestry service had already made up a civvy plug on my truck)
Other thing you can do is pop out a tail light.... tap into the brown wire there, and feed it down under the truck.
ken
25
Houston Texas
Hummm no purple wire? Mabye it's wrapped up in that black corragated wiring wrap. Both trucks i had, had this wire. I'll look at D-RAT's cucv and see if i can find his.
wyliek
Chandler AZ
the brown wire from the trailer is working, i figured out that one is for the Blackout LEDs when i blew the fuse when i touched the wires, but the regular brown wire works good!
